weird heating problem
Discussion in '1983-2005 S-Series models' started by balzackks84, Oct 27, 2002.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Why is it that when ever you go to sell a car it decides to break? I put it in the truck trader this weakend and tonight it acted up. The problem is that its got a 4.3 with a chip and 170 degree thermostat. It usually runs in right around 150-170. Tonight i went to go get gas and everything was fine, drove about a mile and the heater was working fine and the gauge was at its normal spot. Just before I got to my house on the way back i noticed the gauge was at 220! I know thats not outragouse but when its never run above 170 before, even with a heavy load, it scared the crap out of me. I parked it and started checking it out. Theres a small leak on the lower rad house, like i watched it for 30 seconds and the drop never fell from the hose, with the engine running. Now the wierdest part of the whole deal is that the heater quit blowing hot air. It worked on the way to gas but not on the way back. WTF. Any sugestions would be appreciated since its going in the truck trader on thurs. Oh yea, and at idle it jumps from 220-180 spuratically, no noise from the belts or water pump.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Now that it's cooled down, check to make sure that the coolant level is topped off in the radiator. It sounds like it's very low. That will keep enough coolant from running through the heater core. It will also make the engine run hot.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Bad water pump? Even with the bearings good the impeller could have broken off and stopped the flow of coolant.
