weird heating problem
Discussion in 'The Garage' started by balzackks84, Oct 27, 2002.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Why is it that when ever you go to sell a car it decides to break? I put it in the truck trader this weekend and tonight it acted up. The problem is that its got a 4.3 with a chip and 170 degree thermostat. It usually runs in right around 150-170. Tonight i went to go get gas and everything was fine, drove about a mile and the heater was working fine and the gauge was at its normal spot. Just before I got to my house on the way back i noticed the gauge was at 220! I know thats not outragouse but when its never run above 170 before, even with a heavy load, it scared the crap out of me. I parked it and started checking it out. Theres a small leak on the lower rad house, i watched it for 30 seconds and the drop never fell from the hose, with the engine running. Now the wierdest part of the whole deal is that the heater quit blowing hot air. It worked on the way to gas but not on the way back. WTF. Any sugestions would be appreciated since its going in the truck trader on thurs. Oh yea, and at idle it jumps from 220-180 spuratically, no noise from the belts or water pump.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Check or replce the temperature sending unit. If the heater quit blowing hot air....Perhaps the waterpump is on its way out and isn't cirulating water enough to get to the heater core? Might as well check out the thermostat and replace it with whatever is stock temp. Also, maybe the radiator cap? Other than that.....I can't help ya much....Good luck. /forums/images/graemlins/crazy.gif
  3. TITAN
    TITAN 1/2 ton status
    Dec 7, 2000
    245
    Oklahoma
    Purge the air out of the system. It leaked just enough that there is some air trapped behind the thermostat. Or the thermostat is going? I had a s-10 that did that to me about once a year or so. Looked in the rediator and it was full, all fluids were correct, but I would take off and it would go up, and then down. Finally a friend of mine that used to teach at OSU tech, said to purge it and it quit.
  4. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    now that its not 1 am I looked and found the fawking waterpump leeking at a casting seem. Pretty weird. I think im gonna J-B it /forums/images/graemlins/grin.gif
  5. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    grab one of the fins on your fan and see if you can move it if so the water pump is gone cause the berring inside the pump is loose and doesnt make a tight seal on the pump itself and also check your heater hoses and see if they are kinked or soemthing...!
