weird lift question
Discussion in 'The Garage' started by LEEREED123, Dec 12, 2006.
  1. LEEREED123
    LEEREED123 1/2 ton status
    Jun 29, 2006
    384
    BFE, Ga
    i know there is a thread about lift kit fitment but my question is a little different. i am putting a 4 inch rough country lift with springs all around and an extra 2 inch of block in the rear. anyone know what the largest tire i can go with is while doing minimal fender trimming on the corners. i wont be using this rig off road much ( i have another truck for that) and have no hills to worry about a lot of flex. mainly i'm going for looks.
    thanks!
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The front is the only place you should really have fitment issues because those tires can turn. You could probably fit 35's with somewhat minimal trimming.
  3. scooter122983
    scooter122983 1/2 ton status
    Oct 4, 2006
    297
    Fond du Lac, WI
    Im running 35's with no trimming or real rubbing.
  4. LEEREED123
    Jun 29, 2006
    384
    BFE, Ga
    any idea what i could fit with some trimming?
  5. scooter122983
    Oct 4, 2006
    297
    Fond du Lac, WI
    maybe 37s with some minor trimming 36s with minimal trimmng and no inners.
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    If it were mine and I wanted looks I would get some zero rates for the front (and mabey a 3" block in the back if you have the stance where you want it) move the front axle forward an inch and try to fit 38x15.5 swamper radials on it. I garuntee it will rub when flexing but it will look cool as hell. If you don't want to do all that work I would just get some 37s and trim a bit
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Im running 37's on a 5" lift. They fit, but rubbed a little. You could get away with minimal fender trimming (front only) and use this on the street. When I went wheeling however, I had to do some pressty serious trimming.
    -Harrison
  8. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    just go to the top of this forum! tons of pictures for you to look at! a whole thread on this subject
