Weird Noise. What is it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Dec 31, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I just got my blazer back from the shop. New tranny, new distributor, and my Holley projection was tuned up. The truck runs great but is sometimes makes a weird noise. I can only describe it as sounding sort of like a dirt bike. Not as loud and it goes away sometimes. Anyone ever heard of this. I can hear it from the engine area, maybe the projection, or something with the exhaust? The sound seems to be just as loud under the driver side. I am not sure what this could be. It doesnt sound horrible but weird. thanks for you help.
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Did you lay underneath and try to pinpoint the noise? Possibly your trans inspection plate vibrating.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check to make sure the fuel lines aren't hitting the metal firewall somewhere. If they contact the metal you can hear the injectors fire from inside the cab. It makes a weired buzzing noise. Increases in pitch as you rev the engine.
  4. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    When the shop pulled my tranny and I got it back, the gasket between the catalytic converter flanges on the exhaust pipes blew out as it came loose. It buzzed a bit on its way.
