Weird noise...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76GMCJimmyinAZ, Aug 15, 2000.
  1. 76GMCJimmyinAZ
    76GMCJimmyinAZ Registered Member
    Jul 18, 2000
    46
    Mesa, AZ
    Here's a challenge for you diehards. My right front hub makes a tinny popping (I almost wrote "pooping" =)) noise when I back up and turn the front wheels. I replaced the hubs (had superwinches, now milemarkers) and nothing has changed. I have 15X10 Cragar Supertrucks (like Welds). One mech said it was my hubs (before the change). Like I say, it's a tinny sound, not a "heavy" sounding clunk. My truck is @ fly-n-hi offroad today getting the front axle seals replaced, so maybe they'll find something... It's been an annoying mystery for the entire 3 years I've had the truck... Any ideas??
    GUZZLES GAS BUT IT'S FREE AND CLEAR!!!
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    My 15"10"'s have weight's on the back of them that will just gently "touch" every time they pass the knuckle on the stabilizer between the front wheels... Could this be what you are experiencing to?
    http://www.espen88k5.coloradok5.com
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    It could aslo be the front axle shaft sliding around. My drivers side one was well worn (the outer stub shaft) where the clip went on to it. The groove was not deep enough and let the shaft slide past the clip.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  4. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Check your rotors and calipers also, if the pressure isn't letting off on the calipers they can just barely hit and make a noise like you've described.[​IMG]or a brake pad rattling in the caliper.[​IMG]
    <font color=blue>White Knight</font color=blue>
