Weird noises... Help!
Discussion in 'The Garage' started by TXsizeK5, Nov 30, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Ok, first weird noise... whenever I take off, it feels like my rear end kind of rumbles or knocks a little bit, then its fine again. I think theres some play in the driveshaft, would that cause anyhting like that?
    2nd, when i hit 3rd gear (sm465) it kinda makes a windy whining sound... like there wind blowing in the rear tailgate.. but if i put in the clutch or let off gas, it goes away? I just noticed the 2nd noise tonight, but the first problem has been around for a while. Thanks!
  2. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    When I had that whining sound that quit when I took my foot off the gas, it was because my rear differential was low on oil. I have also heard that sometime a diff. will do that shortly before it goes out. I think you should pull the cover and look it over, then fill with a good oil and see if it helps with the noise.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well if its a gov-loc /forums/images/graemlins/eek.gif. but if yur runn'n 10 bolts and those size tires /forums/images/graemlins/ignore.gif. if you can move your driveshaft up and down and side to side by the diff, you need to tighten up your yoke\pinoin nut, mine came loose, i only realized it was loose after i blew it /forums/images/graemlins/rotfl.gif. good luck /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    No, I'm running open differentials... and I checked again this morning, and there isn't anymore play in the driveshaft.. i guess the mechanic fixed that when he rebuilt my t-case. Anyway, i filled it up with fluid, it was missin' bout 4/5 of a quart... /forums/images/graemlins/eek.gif
    So maybe thatll help... my diff leaks from the pinion yoke (is that where the driveshaft conects to the diff?)
  5. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    yea thats wehre they connect, mine leaked there really bad too, to the point everything in that area will never rust out if you know what i mean /forums/images/graemlins/wink.gif, its all coverd with 80\90w. same with my slip yoke by my t-case, damn thing slung oil everyware and now the cab will never rust, along with a few lines on the frame /forums/images/graemlins/thumb.gif.
