weird problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Aug 21, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    everytime i start moving from a stop my trucks lifts up somewhat on one side. Could a locker cause this, or something else like bad springs?
  2. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    do you have a detroit or anything in your rear axle? Did you check tire pressure?
  3. blazing86
    Dec 24, 2000
    290
    yes i have a detroit and pressure is the same
  4. 83PJW
    Aug 18, 2002
    160
    leavenworth, ks
    you will notice a weird pull to one side with a detriot. it is even worse with a standard like mine. is it so bad some times i wonder myself. but i am like that.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    If you've got some ponies under the hood and take off fast then the right rear will drop and the left front will lift. If you've got it in 4wd it can lift the truck up due to bind up.
    If you've got a broken leaf then one side could drop under acceleration.
