Weird question
Discussion in 'The Garage' started by babyburb, Dec 14, 2006.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I drive a Thomas 77 passanger school bus and go over a Load zoned bridge. sign says the limit is 10,000 lb single or tandem axle. The GMVW listed on the specs is a bit over 33000 lbs before my 60 to 70 students. Is this safe? Can anyone explain how they figure out the Load limits in Lamans terms?
  2. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    Never mind. I brought it up through the school and they freaked out. They have been covering that route for years and no other driver has ever questioned it. Brownie points for me!!!
  3. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    lol well good for you, you would think that someone with 70 lives in his hands would notice something like that... give your fellow bus drivers a good lecturing. I read your question earlier but I really have no idea where they get the numbers... I guess they just take the materials it was built with and the length of the bridge make an estimate.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    It's pretty complicated how that bridge max load number comes about. Lots of Engineering Statics and Strengths of Materials to get to a max load that doesn't move. Then they break out the Dynamics book to figure out what it'll hold in terms of a moving load (hint: usually much less than the max static load).
  5. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    your gmvw is gross max vehicle weight which is the maximum your vehicle can safely weigh fully loaded. You are quite a bit below that with the empty bus. Probably still far below that even with a full load of students. You are probably still over the 10000 max limit for the bridge though.
