Weird Sound....Please help
Discussion in 'The Garage' started by zx672, Oct 7, 2004.
  1. zx672
    zx672 Registered Member
    Mar 2, 2004
    48
    Olney, MD
    Got an 84 K5 and everything is great except a weird sound that happens ever so often when I slow down for a stop light, turn, etc. Sounds like a big "thud" and it seems to be coming from the transfer case or transmission. It "thuds" once or twice and then goes away, but it never vibrates. Just sounds like the transmission is downshifting on steroids. Wish I could explain it better for you guys..... Any help would be appreciated. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Mine does that too. Im pretty sure its just the driveline binding up on the slip shaft and unloading when you stop..No harm done...
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine does that too , I think its normal . However if I have it in overdrive , it won't downshift that you can feel , but be in the right gear when I get back on it . /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Slop a whole messa grease in there, it will hold you off for about 6-12 months.
    It's caused by axle wrap changing the pinion angle.
  5. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I would aggree except you stated it did it when you turn also. Make sure your front axle isnt moving back and forth on the leaf spring/pad. If your just sitting in the driveway and turn the wheel back and forth, do you hear it?
