Weird Steering Problem
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BIgJon, Mar 20, 2001.
  1. BIgJon
    BIgJon Registered Member
    Mar 20, 2001
    19
    I have an unusual problem with the steering in my 72 4x4 Blazer. If I turn the steering wheel to the right, it stops at one and a half turns. Once I straighten out, I can then turn the wheel to the left almost three full turns. Its great for doing U turns, but if I have a sharp right turn to make I am in big trouble! I noticed that the front passenger side tire sticks out about 1 1/2 to 2" further than the drivers side. Are the Dana 44's offset like the rear 12bolt GM diff's or is this a possible problem?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ok what I did to fix that was to adjust the drag link between your steering box and knuckel. This is how I adjusted it. I went to an empty parking lot then lossend the center sleve and started driving in a circle then the other direction. I turned the sleave several turns then retest the circle patern. I simply tried to make the circles the same size in bot directions. It seam to work for me know I can make a Uturn in eather direction. Oh ya I also replace the draglink with a new one and made sure the sleave was in the very center of both link ends.
    Oh and yes the front D44 is 3" longer than the rear 12bolt, 1 1/2" per side.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Neither axle should be offset (much) from the center of the truck. Both my front and rear axles are fairly centered in my Blazer...
