weird vibes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Greek, Feb 19, 2006.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    I have a vibration. Its not always there but when it is, it shows up while im accelerating and starts around 25 mph..I just replaced the rear ujoint and ever since then Ive had these vibs. I went under and tightened the bolts and its still there. Im not sure if its the ujoint tho because when i let off the gas the vibs stop. My bro said it could be the torque converter going bad but im not sure.. Anyone have any idea whats going on?
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    did you replace it ?
    when the driveshaft was bolted back up to the yoke on the rear , was it
    greased ?
    see if there is playin the u joint , jack up the rear and put it in nuetral
    wiggle the driveshaft.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Make sure you didn't over-tighten the bearing caps. That will make the bearings go south in a hurry and cause vibes.
  4. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    yep it was greased. also when the vibes started i unblolted the bolts, then rebolted it to make sure they were tight then checked for play but there wasnt any..
  5. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
