weird way of 52" swap
Discussion in 'The Garage' started by basing110, Aug 21, 2005.
  1. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    298
    san diego
    http://www.4wheeloffroad.com/brandpages/chevy/131_0407_long/
    just read that and they didnt move the front perch and it still moved the axle forward 1.5" forward? ive never seen a 52" swap done like that.comments on the quality of that please cause i am wondering why they did that
  2. theitalian404
    theitalian404 Registered Member
    May 7, 2005
    75
    Georgia.
    humm, haven't seen that before w.o moving perch. Im not down with that idea at all... :screwy:
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if you do the math, that actually moves the axle back 2"
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Those are custom springs. I would bet the center pin or bolt is not in the same place as a stock 52 inch spring.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    with all the little snafu's they ran into I think I'd rather move the front spring hanger forward, I remember that article and thinking that it seemed way too much of a hassle for what they were trying to achieve
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Those front springs that they got from deaver is part of a complete type of kit that they make. I was down at deaver a few weeks ago picking up some stuff for work and I was talking to one of there reps. He was saying that they now make and stock those springs for our trucks with the shackle and what not. As a result its a little cheaper then having them make you a full custom set. I dont remeber the prices but I do remember that having a custom set made was about 300 dollars more expensive. In fact that same blazer was down there, its a good lookin truck. Has anyone been down there? There shop is awesome, they said they have been there for over 80 some odd years. Its a really old lookin barn in an older part of santa ana.
  7. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    I run this set-up and it works great. My springs are from Alcan and consist of 11 leaves and a offset center pin, +7 on the back of the spring. They have between 7-8" of lift and with a +2" shackel moved back 5", it has alot of flex (actualy too much!).
    Now the bad stuff, with the stock diff center line a 38.5x15 Bogger gets into the firewall at full stuff, so some hacking is needed. Also with a thick leaf pack like my Alcans theres no room for a zero-rate and high & crossover steering can hit the tops of the springs if you run a heavy DOM tierod or drag link. No wheelbase change :(
    I think I paid like 480$ for the front set with bushings and they flex like crazy.
    It was an easy upgrade without the R&D of mixing an matching leaves for the correct balance of flex/lift and spring life.
    It was my first "custom" leaf spring project and I had little knowledge of what makes a fullsize work offroad.
    It's not the only way to do it but it is a viable option.
    Just my .02
    Thanks Jeff
  8. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    After reading all this I tend to believe that using stock 52's for a flexy front has some great advantages over expensive, custom length springs to acheive the flex
    Mike
