Weld a 14 Bolt article?
Discussion in 'The Garage' started by ChevBlazin, Nov 8, 2005.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I thought I saw an article on this site some time back on welding the spider gears in a 14 bolt FF. I think it was in the Technical section, but there is nothing like that there anymore. It could have been a different site, but I believe it was on here. Anyone know about it?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It was on here , and a member welded his gov loc 14bff too .
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    The article was removed because it is no considered to be an improper way to weld your spiders... Search for the username "kid Jethro" and "Spiderball"... He had a good write up in a post on here with the correct way. Basically you want to weld the spiders and pins in a mini spool-like configuration(spiderball)....
