weld on bead locks
Discussion in 'The Garage' started by MNorby, Jun 20, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Found a thread on pirate once and can't now but it listed all the weld on beadlock kits. What all ones do ya'll know of and any pros/cons? I am looking for a kit that INCLUDES the hardward too.Thanks
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I got mine from rockstomper back in the day and haven't had a single problem since. They do cone but no leaks to this day. there are quite a bit more vendors out making these now.
  3. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    Try DIY4X. here on ck5. He goes by cybrfire, he'll probably chime in later about this.
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Pros,
    Cheap compared to alternatives.
    Customizable
    Durable
    Protects the rim
    Personally I love the look as well
    Cons,
    They do cone in (if you want to call that a con some folks like the look it produces)
    Some say illegal (I've been pulled over with them on in a strict state and nothing was said)I have yet to see it in black and white.
    Rim is permanently altered.(if you want to call that a con)
    They don't lock the inside bead. Cheap ways around this as well.
    Generally I don't do bolts with them for the simple fact that the weight of the bolts would require them to be sent in a different package which negates any savings I could give you short of picking them up at a local hardware store. I also have seen instances where a shorter bolt could have been used. I'd start with 1.75", 1.5" will often get it done.
    I was going to stay out of this thread as I am biased but hey, there it is. Fair as I can be.
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I was gonna buy some DIY4x ones until you found me the those H1 wheels and DRW axles in the same week :)
    Kert's work is top notch.... I'd go with his.
    Kert - I've heard that they're not "DOT approved" but are legal. :confused:
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    With weld-on beadlocks, you are substantially altering how the rim works.......so technically you are voiding the DOT- approval that the rim has when stock. Therefore, again technically, the rim is not legal for use.
    However nobody has been able to produce a vehicle law that specifically states a "beadlock" is illegal. There are companies that make beadlock wheels that obtained the DOT approval with the beadlocks.
  7. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I'm not worried about legality and such. A friend is buying me a set along with himself if I do the welding on his (he got frustrated at his 16.5s last weekend). Money is really no object to him so wanna get the best and was thinking of getting the hardware too to make it all in one bill kinda deal.
  8. wicked_k5
    wicked_k5 Registered Member
    Apr 2, 2004
    13
    Under my truck. NJ
    Shawn at Great lake offroad makes them also. I think he has a special running on them over at pirate.
