weld on beadlocks on chrome rims
Discussion in 'The Garage' started by bigbluesuburban, Dec 5, 2006.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I have a set of 15x12 8 lug rims that I want to install beadlocks onto. My only concern is that the rims are chrome.
    How should I prep the surface in order to get a good weld when I install the beadlocks?
    Is this ok to do? Will there be an inherent weakness?
  2. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    There is no problem welding on chromed metal but unless you are planning on putting some really wide tires on that thing I would reconsider using 12 inch rims.
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Yeah, the beadlocks add what, another inch or so on each side ... so effectively it's a 14"ish wide rim, so you'd hafta have like what, 16-18" wide tires not to squish them? :eek1:
    -- A
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Beadlocks add about an Inch to the width of the rim. 15x12 would measure out around 15x13 or so ish. Depends on bead thickness of the tire a bit and how much you squish it.
  5. dremu
    Feb 27, 2000
    15,968
    461
    Oops. I stand corrected. S'pose it depends on the rim style and all too.
    -- A
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    That will have an effect as well. Some rims have a little more curl on the rim edge. If you were able to add an inner ring you would get more, however, I have tried this and it just isn't feasible with normal brakes.
  7. dremu
    Feb 27, 2000
    15,968
    461
    Ohhh ... that's what I was thinking of, double beadlocks, DIY style.
    Duh :doah: brakes ... I of all people should know that...
    -- A
