weld on frame bracket hunk of junk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, May 10, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    alright, so after hours of work i got no where, the steering box would not bolt on properly period, its even worse w/ the plate on, so tomorrow im gonna take the plate off, any ideas as to wat to do? i have the bracket from 4WPW, no i didnt mail order it, i actually went and bought it. anyway, does anyone have any suggestions as to what might be wrong, and how dangerous is a crack in the frame, i have one it kinda lines the bottom of the frame and then comes back up.
    phill
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I would say take it back and tell them it doesn't line up then order the ord brace ..
    Could it have been not just right lined up...just a thought...mike
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    How did ya line it up when ya welded it on? Te best way to do that to eliminate misalignment issues, is to just bolt the brace on, then weld it. Remove the bolts, stick the box back up there an re-insert the bolts. You are gauranteed perfect alignment doing it this way, Asumming of course that the brace holes actually line up with the holes in your frame.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Thats the way to do it/forums/images/icons/cool.gif
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If your frame is cracked, you need the kit. If it is not cracked, you can use the ORD brace to prevent cracking. If you have the holes misaligned, you will have to CAREFULLY drill them out enough to get the box on. OH....the crack is REALLY dangerous.
  6. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ya the holes dont line up at all, im gonna remove all of it, bring it back to 4WPW(bastards) and have a welder fabricate something for me.
    phill
  7. ratpack7
    ratpack7 Guest
    YOU WANT TO FIX THE CRACK!!!! Trust me mine busted clean in half and I had the steering box floating. I was lucky and knew a guy with a welder ( Thanks Sky ). But if I had done any more driving then I had before I noticed it I would have been on my roof in a ditch some where and I havent put the roll cage in yet.
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You also, more often than not, have to replace the bolts with longer ones. I bought my longer bolts at the local Tractor Supply. Bolted the brace up to the frame with all bolts in, marked tact it, removed the pump, and proceeded to welding.
  9. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    You will pay as much to have one fab up then to just buy the ord one....mike
