weld on kit
Discussion in 'OffRoad Design' started by wild-will, Sep 3, 2003.
  1. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    i just used your weld on frame repair kit and i had alot of axtra metal i had to cut of the kit. whats up with that?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Without checking a lot of stuff out, it's hard to say, they run a bit big normally, I think they're built to be welded on the inside corner as they overlap the frame by just a bit. It can generally stand a bit of hammer work to make it all fit just perfect.
  3. wild-will
    Aug 21, 2003
    185
    Oak town WA
    I had to get the acetaline and cut almost the whole bottom piece to my specifications
  4. CK5
    May 19, 1999
    21,625
    702
    CO
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The bigger piece should be about as tall as the frame rail on the truck. When I went to install my weld in kit, I thought it was too big to, until I lined everything up.
