weld on steering brace installed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Aug 10, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I hooked up with some new CK5'ers here locally. Great group of guys. jamiemac and his brother ben. Thanks Ben for welding on my brace. I noticed a $hit load of difference on the ride home. No more popping in turns, it was ALOT stiffer steering wise. Looks forward to wheelin with you guys!!!!
    Does anyone have a grinding disk I can borrow?[​IMG]3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Good deal. Does the brace weld on from outside the rail?
    <a target="_blank" href=http://fwp4x4.rockcrawler.com>fwp4x4.rockcrawler.com</a>
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yes, it goes on the outside of the frame adn the bottom side.
    Im not sure that Stephen actuakky makes these braces, I think he is just a seller of them. They look very mass produced, but I could be wrong. The only problems we had were the holes didn't line up good, and the edges had to be ground down to fit real good and we had to beat the living dog poop out of it in some places. Also we had to weld down one side and then bend or force down the middle then tack that and finally work our way toward the front with the same process. Also had to trim a little off the front to allow the factory bumper bracket to mount back flush to the frame.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks. I'm running the ORD bolt in brace, but after all the talk seems like I need to look at adding the weld on one as well. I never actually saw one installed, that's why I was askin. Thanks for the tips.
  5. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Gotta Love the K5 Bretheren....
    We're a unique bunch of truck owners.. [​IMG]
    Round Rock, Texas I haven't failed, I've found 10,000 ways that don't work. <a target="_blank" href=http://www.rocko.rockcrawler.com>www.rocko.rockcrawler.com</a>
  6. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    I have the weld on brace inatalled if you want to take a look. My frame has serious damage. Also have the bolt on brace.
  7. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Where did you get your brace?
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Go here to get all kinds of cool stuff.
    <a target="_blank" href=http://www.offroaddesign.com/>http://www.offroaddesign.com/</a>
    my truck's not dirty, it's earth tone paint
  9. Medman74K5
    Jun 7, 2001
    48
    The weld on brace was installed when I bought the K5. I didn't check the frame as good as I should have, looks like the previous owner tagged a tree or got hit by someone. I've since installed the bolt on brace as well. ORD and JCW have the weld on kit. I picked up a 75 last mo. so I have a good frame to work with.
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks Sean, Where did you pick up the 75 at? Just curious, I've been keepin my eye on one in Chino that's been for sale for awhile now.
  11. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    It was the ORD brace. But like I said above, I think stephen is just a reseller for another company on the weld on brace, but I may be wrong.
  12. Medman74K5
    Jun 7, 2001
    48
    I bought it from a guy in Dewey for $200. Has a SM465, NP205, Dual tanks (which I've never seen on a K5), fact. roll bar. Needs rear axle(4.10), front springs, front clip &amp; hood (has fenders), steering column, hub &amp; rotor assembly, spindles, engine. Trying to decide wether or not to combine the 74 &amp; 75 or start seaching for parts. Two K5's would be nice, the wife said she would drive the 74 since its an automatic. I'm thinking about it.
  13. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    The brace I installed was two pieces..welded inside and out, creating a box...very strong....from a shop in Tucson, I think....
