Weld on steering brace.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Aug 11, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, as you all may know from the other post, I have installed my weld on adn bolt on steering brace.... Thought it was going to fix a popping/clunck kinda noise only while driving and turning left (while driving) Like taking a fairly sharp left at say a red light or intersection.
    The problem Im having is that I thought the frame crack was causing this so I installed the brace(s) adn the popping is now less frequent but it is still happening.
    ITs not the body tweaking, creaking, or gears or tranny, cant feel it in the steering at all. But it feels like the frame below my feet is being hit with a sledge hammer(ok a small one) but none the less.
    Any ideas what this problem is?????????
    Does anyone have a grinding disk I can borrow?[​IMG]3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  2. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    I would check your crossmember were transfer case sits, had a similiar prob. bolts were loose. Maybe front shackles or body mount.
  3. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Mine did that and drove me crazy. It was the body mounts they set right under your feet.Had to have the body reinforced in that area on both sides.Only did it when turning
    A Big Hammer Can Fix Anything ..
  4. My 82 was doing the same thing and it drove me crazy untill I figured it out.My springs were hitting the frame at the shackle
    and the top bushing was also wore out.I was going to buy longer shackles but I traded her off.But this could be your problem also. Just my$.02
  5. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    Did you space the front fenders with something other than OEM?.. My truck has creaked and popped since I put it on the road..I believe the lower fender bolts are guilty.....I installed a brace, also...pretty much bullet proof...
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    WEll, My spring bushing are brand new poly's that came with the lift, right at a year old. My floor is in A1 condition, so I dont think its the body mounts, though I have thought about that.
    I thought about the shackle hitting the frame, which would make since, however why would it only do it half as much as it use to now that the frame brace has been welded on other than it doesn't let the frame flex as much keeping the frame further away from that shackle. I'm gonna pull it in the garage today and check every fing bolt on the truck from the doors forward. This is starting to piss me off somehting fierce.
    Thanks for all the ideas. Keep them coming....
  7. Not the spring bushing Brandon.There is also a bushing in the frame where the shackle bolt goes through it.Check the rivets around the crossmember and see if they look ok.
  8. Not the spring bushing Brandon.There is also a bushing in the frame where the shackle bolt goes through it.Check the rivets around the crossmember and see if they look ok.
  9. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Gee, which post to rely to? LOL!!!![​IMG]
    I figured that much.... The crossmember rivots from what I can tell are all good. I dont see how Im gonna be able to make it shift enough to find them if they were the problem if it takes the truck moving adn slinging the 5500 lbs from one side to the other to make it pop. Less Hercules decides to stop by adn lend a hand. [​IMG]
  10. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Some areas that I've found in the past to make noises are: loose/cracked front bumper mounts, loose rivits in the cross member and spring hangers, springs bushing sleeves that were over torqued and are loose in the mount, spring bushings that are worn and loose body mounts.
