weld up a 12 bolt
Discussion in 'The Garage' started by Ruff_ryda_420, Aug 7, 2003.
  1. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    i want to weld up my open 12 bolt, is it just the same as weld the spider gears on a 14 bolt (as per the tech section)?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 12 bolts are quite a bit different than 14 bolts. I think that the best way to weld a 12b is to weld the side gears to the case, but you have to be a pretty darn good welder to get a good strong weld like that. Personally I don't think it's the greatest idea, for a variety of reasons. First off, it won't be nearly as strong as a welded 14 bolt. Second off, it's probably going to cause you to break other parts like axleshafts. </font>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    We welded mine up. Took the cover off and rained the fluid. Cleaned out all the lube we could then welded all the spiders together. 16 gob welds in all. We used a rod with nickel content... It held up fine even to a high throttle, bouncing rear-end situation!
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm....I know some say it will work just fine. I've done 10+ sets of 14b spiders, and have had a welded 14b on a DD for 6 or 8 months. I would never weld a 12b. First time I drove on pavement with my welded 14b, I was shocked at how much tension and stress etc etc, that the shafts and everything else where taking. I would would think you'd be tempting fate if ya welded your 12b.....It's my opinion that it would blow apart fairly soon.
  5. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I agree on the high stress placed on the shafts when welded, especially on the street. I broke 2 D60FF rear shafts on the street while making turns, so I wouldn't do it to a 12B if its street driven a lot. My $.02.
    Will
