welded d60f steering
Discussion in 'The Garage' started by REDCRO_REDNECK, Sep 21, 2006.
  1. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    has anyone that welded a front end and used crossover steering have trouble getting their wheels to turn?
    I might be welding the front spiders in my d60 since I wasted the carier in it. I would like to avoid putting hydro steering in a truck that is going to be used for mud?
    could the pump mod for hydro assist help with how the stock box turns things?
    just shoot out some ideas I have on my next truck build need it to be cheap.
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you could always jump out and unlock a hub. it will be harder steering with it welded.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Its going to suck without hydro assist.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You will become the master of 10 point turns, better get a cooler for your power steering
  5. REDCRO_REDNECK
    Apr 7, 2005
    241
    mo
    I get what you guys are saying but I am not hearing I did that and hated it.
    how are detroit lockers any different when the throttle is pegged?
  6. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    when you let off the gas with a detroit it unlocks and allows you to steer. a welded diff is locked all the time. i put a lockright in my front d60 and can feel it want to pull straight when on the gas, but off the gas it will unlock.
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Wait for Ira to post up. (Sandawgk5)
    We welded his spiders a month ago or so.....he can't turn on pavement with crossover, no hydro, without unlocking a hub. Even in 2WD.
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I put a spool in a dana 44 with 36" sx's. Burnt up 3 power steering pumps in one day. Steering sucked, had to always unlock a hub to make any decent turns. Then upgraded to a dana 60 with a detroit and there was a night and day difference. I could really use hydro assist but its ok for now. I would wait until you could afford hydro assist.
  9. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i know people that had had welded D60 fronts and they had trouble steering on the trail with full hydro
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Its a pain in the arse! If you have the $$ do it right. If you are a cheap bastard like me, weld it up and deal with it. Nothing like the traction but it doesnt turn for ship!
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    And then there is the issue of having the Ujoints phased when welded. There was a post on here some time ago about this very thing. Some liked it and some didn't. It was starting to sound like if the shaft joints were out of phase the steering became even more difficult which seems to make sense.
    I'm going to try the welding route on the blaz. I also have full hydro steering and drive slugs so I will report back to let yall know what I learn. At least with welding if you don't like it you can put a locker in later and get rid of the welded stuff.
  12. REDCRO_REDNECK
    Apr 7, 2005
    241
    mo
    That is part of the appeal my front carier is wasted, I have another carier but I would have to go deeper then 410
