WELDED FRONT QUESTION
Discussion in 'The Garage' started by 87BrnRsd, Aug 30, 2003.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I have an 87 K5 that will be recieving a 14ff rear with detroit and 4.56's. The problem for me is finding a front end to match. Well, I located one (a D44) with 4.56's and has already been converted to 8 lug to match the 14ff. The only problem that it has that I dont like about it is that its welded. My question is that do yall who have experience with welded front ends think that it is wort it for me to buy this and not have it break? I just dont want to dish out a good sum of money for something that cant hold up to that stress. I wont be doing anything like moab, but i will make the occasional trip to uwharrie, and maybe tellico in the future. I will also be running 37" tires. Oh, and one more thing, can i run it in 2wd with both hubs locked so i can turn it and have 4wd on the fly? And, can I run it with just one hib locked sometimes in 4wd so I can turn?? Thanks.
    -Harrison
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    My crystal ball tells me that with a D44 with a welded up diff and 37's will = breakage!!!!
    I'd keep looking personally.
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I'd have to agree with waxer. Keep looking. I don't think you'd like it very much. Good for some mud racing though.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I broke my open 10 bolt front with 4.10s with 38s and it hasn't seen much use yet...although it just depends on how you drive.
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    depends on how it's welded...could just be that all you'd have to do is replace the spider gears.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    -Harrison
    <font color="green"> I think that if you wheel very hard it will break pretty quickly, not neccesarily at the carrier, but shafts and u-joints for sure. If you run in 2wd or 4wd with the hubs locked then you will have a hell of a time turning. If the hubs are locked then the front tires are locked together and will not turn at different speeds to make turning easy. If you run with only one hub locked, whether 2wd or 4wd, then it will turn without a problem; however you will be sending all the power tha tgoes to the front end to the one wheel, so you are pretty much gauranteeing breakage. </font>
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    cant you just though a lock right in there? I heard there VERY easy to install
  8. 87BrnRsd
    Apr 21, 2003
    2,457
    Its already welded. /forums/images/graemlins/angryfire.gif
    -Harrison
  9. 87BrnRsd
    Apr 21, 2003
    2,457
    Hey, do you still have that 10B front with 4.56's for sale man?
    -Harrison
