Welded new spring plates!! *pics*
Discussion in 'The Garage' started by midnitewarya, Feb 11, 2006.
  1. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    Well, I'm finally at the end of the tunnel. On Sept. 7 2005, my K5 blew it's gov-bomb. Now, all these months later, after rebuilding a '98 14bff, yesterday I welded my spring plates. Stephen (neverendingproject) came by and helped out a TON!. Now that 14b is resting peacfully under my Blazer. I just have to finish running my brakes lines, and I'll finally drive my baby agian. I'm soooo happy!:D:D:D:D
    BTW, Stephen, you need to post up some pics of your motor. That thing needs a write up or something, it's awesome.
    Stephen making sure everyone knows who the man is-:p:
    Kinda out of focus, but a sweet weld nonetheless- (Thanks for the help Stephen)
    Al
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    looks good!! and boy thats some nice dry/dead grass your welding on!
  3. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    :D Yeah, thats not usually the best of ideas ...
    Luckily, it had rained all morning, so the ground was pretty damp.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    whats he got for a motor????
  5. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    Correct me if I'm wrong Stephen,
    It's a stroked 383, vortec heads, w/tbi. It looks fantastic. He has everything powdercoated. It's gonna be a real torqer whenever he gets the rest of the truck put back together. :wink1:
    Al
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Nice work. :waytogo:
    Careful with those stock 16" steelies... they bend if you look at them wrong :doah:
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    post pics of it under ur truck now!!!!
  8. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    Thanks!
    You should see the other side, its a totally differnent rim.:D Those are just for pushing aroung the yard. I ordered my 35" BFG A/Ts on 16x10s today. I decided to switch to all 8 lug instead of running 8 in back and 6 up front, so I ordered all new 8 lug wheels. I also got the 3/4 spindles and hubs for the front, just got to pick up the bearings and seals on monday. It's funny, cause it had brand new 35" BFGs on 15x10 6lugs when it blew the carrier, they are gonna go up for sale in a week or so, but thats a different thread.
    Al
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    welds look great. just watch those perches, i had some just like those and folded them right over my second time out. i had my rear axle in the front hole, with it folded over, the centering pin wasn't even in the hole. on the drive home i could feel the rear axle moving back and forth even after i took a sledge hammer to it to beat it back up the best i could.
  10. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    :eek1:
    I have them in the center hole right now. They are the same thickness as my 10 bolts plates, but not near as thick as the original 14b plates. Thanks for the heads up!
    Al
    Pics tommorow after it's light out...
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i put mine on my 14bsf, they close to the same thickness if not the same as the stock ones. i didn't think that could happen, nor have i ever heard of it happening, but i did it. here are a couple pics of what they looked like afterword
    i ended up using 2.5" .250 wall square tube with the ends capped with 5/16" plate for the new perches, looks 100 times stronger and weigh alot more.
  12. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    just out of curiosity, what kind of welder is he using? And what took you so long to get it rewelded?
    Just messing with you, glad your getting it together :saweet: :burb:
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    looks good.. especially with flux core ? and a 135 lincoln...
    a little suggestion... keep the torch on the puddle at the end of your weld for a second,,, and then hit the trigger.. or weld thru just past the end of the weld... then youll be sure its complete from end to end and you wont have a crater
    nice job!!!
    cam
  14. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    Well, ahem, it's a Lincoln 175. :D But you called it, I was using flux. It was my first time using it, and in the futire I think I'm gonna pick up some gas first. I didn't like all the splatter while welding, it made me a little nervous at first.
    Thanks for the tip on finishing a weld, I'll be sure to try it out the next time I'm out there.
    ...It took soooo long because I have 2 kids in daycare. Need I say more? My K5 isn't my DD, so I wasn't in a rush to get it done.
    Those spring plates scare me. :eek1: I like the idea of using square tube to fab some up.
    Thanks for the input everybody!
    Al
  15. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    easy way to make boxed tube perches. 2.5 x 2.5 1/4 wall square tube and 1/4 plate or close to that. cut the tube to the length you want and cut patches and weld to ends. then cut arch in them to match the axle tube. drill center hole where you want it. and weld to axle . also it gives a bit of lift over stock .
  16. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    plus u can get 1" lift :p:
  18. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    *** responding and not hijacking***
    To appease the masses and my good friend Al (midnitewarya),
    here you go, he pretty much on with the specs, but there's a BUNCH of goodies that he didnt mention.
  19. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Al, Ill get some 3/8 steel we can weld to the front and back of those perches to beef em up if you want, just get me some rough dimensions, and I'll cut em out.
  20. midnitewarya
    Dec 1, 2002
    1,726
    20
    SoCal
    I got some 1/2" steel lying aroud from the old plates, I'll see what I can do with that. :D You totally stole my idea...
