welded spiders
Discussion in 'The Garage' started by nicotine, Feb 20, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i have a 12 bolt and would like to weld the spiders in it before a 14 bolt goes in. my question is if that it is the same to weld the spiders on a 12 bolt as it is one a 14 bolt? said here http://coloradok5.com/welded14bolt.shtml
    anybody ever run a 12 bolt welded any breakege problems? /forums/images/graemlins/ears.gif
    also is a welded rear act like a spool type rear end on the street? if so what charicterists?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I just flat out wouldn't weld the spiders in the rear if it's your daily driver used more on road than off.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Yep, just weld up the spider gears, yep acts just like a spool. No more differential action, inside and outside wheels spin at same rate so turing becomes an issue. If you want a cheap "spool" and dont drive on the street much try it. Probably best to do if mostly a trail vehicle like 4xcrazy suggested.
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Its not a big deal, really. I run a detroit in a daily driver and know several people with welded rears on daily drivers.
  5. nicotine
    Jan 11, 2004
    116
    how long do welded rear ends last?
    yeah i know dumb question with welds could last 10 minutes or 10 years?
    anybody run welded on 12 bolt any problems?
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I have been running my rear welded for about a year and except for accelerated tire wear and chirping through tight turns I have no problems. I have towed a Jeep with it, I have towed a trailer with it and it's my daily driver also. To make it strong you need to weld the spiders and then weld them to the carrier, welding the spiders alone is not strong enough. If you are decided on the 14 bolt swap later just weld the 12 bolt and have fun until it breaks. If you don't wheel it to hard and just want some extra traction you should consider a lock-right, they are cheap and plenty strong for a 12 bolt.
  7. nicotine
    Jan 11, 2004
    116
    how much power you running to those welded spiders?
