welder question
Discussion in 'The Tool Shed' started by 1983Blazerkid, Nov 10, 2006.
  1. 1983Blazerkid
    1983Blazerkid Registered Member
    Nov 12, 2005
    98
    brownsburg, in
    does anybody know what the differnce is between the lincoln pro mig 175 and the SP-175+? :confused: didnt know if the pro mig was a cheaper welder or what? just want to know before i buy it. thanks cody
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  3. 1983Blazerkid
    Nov 12, 2005
    98
    brownsburg, in
    i get the differnce between the Sp-175t vs. the sp-175+ just dont get why they have three differnt 175 amp weldors?and the Sp-175t being tapped control just like the pro mig 175
  4. 1983Blazerkid
    Nov 12, 2005
    98
    brownsburg, in
    anybody? anybody work for lincoln here? lol
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Straight from Lincolns home page.
    Trade Name Output Range
    SP-175T 30-175A
    Welding Specifications
    Rated CV Output Amps/Volts/Duty CycleOutput RangeWire Feed Speed Range (IPM)Wire Feed Speed Range (M/MIN)Solid Wire Size RangeCored Wire Size Range130/20/30%30-175A DC50-4001.2-10.2.023-.035".035-.045"
    175 Plus 25-175A DC
    Welding Specifications Rated CV Output Amps/Volts/Duty CycleOutput RangeWire Feed Speed Range (IPM)Wire Feed Speed Range (M/MIN)Solid Wire Size RangeCored Wire Size Range130/20/30%25-175A DC50-4001.2-10.2.023-.035".035-.045"
    http://www.mylincolnelectric.com/Catalog/equipmentseries.asp?browse=101|241|
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I have an sp175+ and have also wondered about the diff. between the pro mig 175 and the sp175t. Does the pro mig 175 come with accessories like the cheapo welding shield and slag hammer? I think that they may be the sam machine, just one comes with those "ready-to-weld" accessories.
  7. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    SP-175T• Large easy to set knobs provide 5-position adjustable tap voltage control and continuous full-range control of wire feed speed.• Large easy to set knobs provide 5-position adjustable tap voltage control and continuous full-range control of wire feed speed.
    SP-175 Plus • Continuous full-range adjustment of voltage and wire feed speed allows for fine-tuning of the arc and precise control of arc energy, or heat input.
  8. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    the T is for turbo...........
    pad.
  9. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    This is an email I received from Lincoln.
    Dear Mr Vaughn,
    The only difference between the two units is the SP-175T is a Tap
    control were the SP175 Plus is Continuous Control. Both units have common
    specifications
    Cored wire size range .035-.045"
    Input Voltage 208,230
    Polarity DC
    Primary Process Mig/Flux-Cored
    Rated CV output amps/volts/Duty Cycle 130/20/30%
    Solid wire size Range .023-.035"
    Wire Feed Speed Range (IPM) 50-400
    Wire Feed Speed Range (M/MIN) 1./2-10.2
    If I can be of further assistance please email me or call direct.
    Sincerely,
    Glenn Cvar
    Warranty Rep
    216-383-2288
    glenn_cvar@lincolnelectric.com
    I bought a Hobart 140 a while back and have found a couple of instances where the continous control would have been nice as compared to the tap control my unit has. My next mig will be a Miller 175 or 210.
  10. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    But he want's to know the difference between the pro-mig 175 and the sp175plus.
  11. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I didnt see a listing on Lincolns site for it, but I did find this.
    http://www.hotrodders.com/forum/lincoln-welders-there-difference-79691.html
    I wanted to know myself on a few of these Models, so I called the Lincoln Technical Department. Nice guys, and they told me that the Sp175T and the Pro Mig 175 were identical, except the badging. One is a "retail" Product (Pro Mig-read Lowe's), the other for the Lincoln Distributors.
    I am not certain about the Weld-Pak, however-
