Welder & trailer progress (oh noes! dodge!)
Discussion in 'The Garage' started by botboy, Oct 24, 2005.
  1. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Just thought I'd post up a few pics of what I got done between last weekend & this weekend:
    Still "under construction", Not quite road-ready yet, still gotta:
    - weld seams where frame rails were notched to be bent in
    - add jack in front
    - Find a couple of taillights for it (others were sold before I got the truck)
    - wire in a 4-pin connector for hooking up to tow vehicle
    - get registered so I can take it on the roads
    - Weld in some threaded steel plates to secure ranger down.
    - weld in oxy/acetyl/argon tank mounts & securing mechanism
    - weld in some toolboxes for holding torch, regs, plasma cutter, etc
    - fire extinguisher, electrode case holder, wire boxes/holders
    - going to put some 1000W lights on the back of the trailer for working at night
    - remove the vapor canister from the side of the frame, cap vent holes in gas tank, add hose for filling & switch for turning on fuel pump for additional fuel carrying capacity
    Here's a pic of the ranger in the back of the trailer. With the ranger about 1.5' back from the front of the bed weight distribution is about 50/50, so moving it all the way forward with some additional toolboxes on the back should put it closer to where it should be. As is, at least I can move it around the farm easily behind a truck or tractor and it doesn't try to tip backwards and dump all my stuff when pulled off the ball.
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Thats a beefy welder! Mig? Arc? Both?
  3. Winter Hill Gang
    Winter Hill Gang Registered Member
    Oct 17, 2005
    46
    Live from St. Mary's
    for sure mig, as you can see the spool of wire in the picture. ;)
    looks like it might be dual tho'
  4. botboy
    Aug 11, 2004
    225
    Delano, MN, USA
    Everything :D
    Seriously though, its a multiprocess machine that does AC/DC constant current (stick/tig) & constant voltage (mig) as well as a 10kw generator W/taps for 120 & 240 volts.
  5. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    are you going to use the truck/trailer gas tank as a back up for the welder unit?
