welder ?
Discussion in 'The Garage' started by hd-10, Feb 8, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    chicago electric 90amp flux wire welder would this be a big enough welder to weld rollcages and any tubing projects?
  2. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I'm a fairly new welder, just finished a welding class actually. It seems to me a 90 amp welder would be enough to go up to maybe 1/8 thick but that might be pushing it. IMHO, I wouldn't weld something as critical as a cage with a low amp Harbor Freight welder.
    If your a good experienced welder, you'd probably be fine.
    Just my opinion.
    Scott
  3. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    what size should i be looking for?
  4. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Really depends on what you want to do and what kind of power you have in your garage.
    If you don't have 220 in your garage or a generator, then your limited to 110 welders obviously.
    I'd get the highest amperage one you can afford. If your looking to keep cost down, look around for a used Miller, Hobart, or Lincoln mig box. I believe all Mig boxes will run flux core and you can always add gas later to do Mig.
    What thickness of tube do you plan on making the cage out of?
    heres a basic guide for wire thickness material thickness.
    [​IMG]http://www.hobartwelders.com/techtips.html#mig
    That site has some good info on basic welding.
  5. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Sorry about the image. Noob here trying to figure out all the ins and outs of posting... :grin:
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I would love to see that chart. Try removing the [​IMG]
  7. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
  8. cbbr
    Jul 17, 2004
    14,681
    Link works great. Thanks. I would leave it at that.
  9. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Ok.
    I believe Cragrat builds some serious cages, you could ask him and he could probably give you a lot more information than I can.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    That welder will do just fine for normal rollcages and small things like that. I have one smaller than that and have done all of my own work (check my sig there is a lot of welding on my K5) and I have not broken a weld yet (ruined a lot of tubing though). It will be a little slow but with enough practice it will do fine.
