welder
Discussion in 'The Tool Shed' started by surpip, Jun 20, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i think i have setteled on the lincoln 175
    thereis 2 models the sp175t and the sp175+ the + is a hundred dollars more and i cant figure out why
    little help please
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    The + has a infinite voltage setting while the t has a 5 way adjustable power setting...
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    if you had your way, wich one would you get?
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    If I had the extra $, I would go with the infinite voltage control. However, for the average user, like me, the 5 point adjustment would be fine...
    btw, I own a SP 135+ and it has been fine for everthing I have done, except welding some 1/2" plate. I had to make a couple passes on it...
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale.. 5 position should be ok for you..
    good choice.. check netwelder on wbay.. they are pretty cheap usually
    cam
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I Have the sp175+, infinite voltage model. I like having the infinite knob, where you can tweak the voltage a little bit to get the weld right.
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'd spend the extra hundy...the infinite voltage is a Godsend IMO. My millermatic 135 has the infinite voltage and it is awesome.
    Rene
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Theoretically, you can do just fine with the tap version by using other techniques to control the weld rather than fine tuning the voltage. BUT, I prefer to have the infinite voltage. My MM175 has infinite and while using it tonight on some heavy channel I tweaked it just a bit hotter than I normally expect on that size material to get it just the way I wanted it. No taps for me...
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    welp looks like ill get the + than
    thanks for all the replies
