WELDERS... What about Gasless?
Discussion in 'The Garage' started by K5thatShmobs, Oct 2, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im purchasing a welder soon, and Ive been seeing some gasless models on the market... Does anyone know how they compare to traditional gas welders?
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    You just need to use flux-core wire. I have a wire-feed welder and haven't hooked up the gas. I have been able to do whatever I wanted to my blazer without gas.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i have the gasless wirefeed from sears and it works great for small stuff like sheetmetal and i havent tried it on thick stuff yet but it seems that it would be alright for stuff that doesnt have too much stress on it.plus it was only 200 dollars and a new spool of wire for it is onlt 12 bucks down at the hardware store. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
  4. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    I have a mig & I always use it gasless. It is fine on body pannels & I did a weld on a body mount pearch & it went fine.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Mine's a Lincoln WeldPak 100. I bought the gas coversion kit for it, but it's still in the box in the garage. I've had excellent results with using the flux-core wire. /forums/images/graemlins/cool.gif Lincoln makes a bigger one now. I think it's the WeldPak 155. If you can afford it, it's capable of welding heavier stuff than the 100 can do.
  6. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    I sent you a PM. I hope it helps you with your purchase. Let me know if you have any questions.
  7. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    my vote is for the Lincoln 251 with argon mix
  8. harry
    Feb 9, 2001
    106
    san diego, CA
    /forums/images/graemlins/blush.gif gettiing my welders mixed up. I was talking about the Millermatic 210. /forums/images/graemlins/tongue.gif
  9. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    MillerMatic 210. Does anything you want. Can also be used to weld aluminium with the spool gun. Theres a good right up on offroad.com by Depdog
  10. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Gasless leaves a lot of splatter. With gas you have a better looking weld. It is not any stronger, but it sure looks better
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have a Sears gasless/MIG welder also.
    I just came in from doing some mig welds on my doors (where I had some stress cracks.)
    MIG welds are a helluva prettier than flux core!
    But I'm having a problem. I kept blowing holes in the door. Small one, yes, and I fix them by welding up the holes. But I can't figure out what I'm doing wrong.
    I have the voltage set on 1, which is the lowest available and is also what the guide recommends for 24 g sheetmetal.
    I tried wire speed all the way from 1 to about 6, and I still have holes randomly.
    I think my problem may be with the wire tension. I'm at a loss as to how tight it should be. Both on the roll of wire and also on the knob that presses down on the wire where it enters the spool feed thing.
    I'm sure they are both too loose now because Ikept loosening them when I had 'stumbles' when the wire was feeding during welding.
    I need to find my owner's manual for the thing because when I set it up for flux core I followed the steps and I didn't have this problem...
    -- Mike
  12. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    You can't run a continuous bead on 24-20 gauge material. I usually do 1/2"-1" and then move elsewhere and do the same. Anything more than that overheats the material too much and causes distortion as well as burn through.
    Rene
  13. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    when i adjust mine it doesnt have to have but a little tension on it to keep the wire in the runner on the wheel the tensioner sits against.when you pull on the wire on the other side it should still come out but have just a little tension.if you dont have the gas in the mig,you are supposed to use the flux core wire so that it burns right when you start to weld.this may be why you are burning holes if you are not using flux core wire.this is what im told so dont quote me.i think maybe you are hitting the metal all in one place to hard.when welding the sheetmetal it gets really hot at the point of contact.so if you are welding a long line maybe 3 inches or so it is best tospot weld the ends of the crack and then work your way in so you dont heat up trhe metal so much in one spot.i was getting the same effect until my buddy told me that.
