Welding 14bFF axle tubes?
Discussion in 'The Garage' started by Mudbug1979, Oct 4, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    How many of you have welded the axle tubes on their FF? I know that it's a pretty strong housing, I was just wondering if it would help out in the rigidity of the whole thing. Preventative maintinence ya know!!!!!
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    From what I've heard the tubes are just pressed in.
    Because of that I'm going to lay a couple welds in the seams to keep them there.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just pressed in? Not at all... They are pressed in and then rosette welded through the housing collars. Welding the tube on the outside is generally considered not ideal due to the stresses placed on the housing, but lots do it without bad effect. This point has been debated to death and "weld or not" comes down to who is doing the talking. I have considered partially welding mine just because some people have had the rosettes break loose and let the housing turn, but that's very rare. And I say partially welding (as in a couple of 1-2" long beads rather than a full fillet all the way around) since it would not be nearly as stressful on the housing collars as a full weld would be. Sort of a compromise approach…
  4. Mudbug1979
    Aug 4, 2002
    439
    Yeah, that what I was thinking about just doing a strip across the top and bottom. One of those "Just In Case" welds ya know. /forums/images/graemlins/waytogo.gif
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How often do you see the welds crack, or the tube twist in the housing. /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah I guess so, I knew the fronts where that way, I haven't payed that much attention to the 14b yet, I got my cover done and ground down.
    Yeah just a tack weld to help out, I wouldn't try to seam seal a axle tube. /forums/images/graemlins/waytogo.gif
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have a project 14bff I'm working on...
    and I was thinking about this subject myself...
    but I'm going to weld an axle truss to it first..
    so the tubes don't pull. /forums/images/graemlins/thinking.gif
    About 4 months ago...
    I popped 2 spot welds...rockcrawling at Badlands..
    So..I had to MIG the spot welds...
    The housing is a ductile cast...so welding to it...was a breeze. /forums/images/graemlins/peace.gif
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are going to weld it just partially I would weld it up front and back and leave the top and bottom.
    When I get some bigger tires I'm going to just weld the whole thing and add a truss in there as well. /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/dunno.gif
