Welding 60
Discussion in 'The Garage' started by 84CUCV, Aug 10, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    This will be on my DD. I was thinking this would be good till i can get a no spin. Only going to be running 38s. My friend is running 42s. i think he might have some problem.
    as alway thx guys
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    front or rear?
    If in the rear, it should be fine if you do a good job. If in the front, I would advise against it.
    If it's in the front, it will not allow you to steer with the stock steering. You would need either hydro-assist or full hydro steering to turn it. It would also wreak havoc on your hubs and u-joints. Now, if you really want to have a welded front end, keep only one hub locked in. That way you can still turn and you still have the "option" of both front tires pulling.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sounds like too much work to lock your front end. If you can afford it, get a lunch box locker.
  4. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    if its your dd, prepare to watch the rubber disappear...
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    yea its a DD. Would only use it offroad. What is a lunch box locker? that is a new one on me.
    thx
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    A "lunchbox locker" is one that you can install in your existing carrier. You may have to pull the carrier out, but it won't require a professional or experienced person with the proper tools to set up the ring and pinion again.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK where can i find these for cheap? Thats why i was going to weld it up for cheap. thx
