Welding a 12 bolt gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HD, Dec 31, 2003.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I was reading the tech article on 14-bolt axle welding and was wondering if that would work for my 12 bolt. If I do this I would carry an extra set of spider gears, just in case I broke something. So tell me what do you think.
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    You'll probably most likely break something if you do it like that, especially if you drive on the street. IMO, you'd be better off to weld the spiders to the side gears and then weld the gears to the carrier. Be sure not to weld the cross pin, it will need to come out if you have to remove the axleshafts. You may still break something, but it will be a little less likely.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no, do not do that, go buy a posi unit for 12 bolt and have it put in
    do notg weld gears for street use
    that is a horrible no-no
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Welded 12 bolt on street with 31"+ tires: /forums/images/graemlins/1zhelp.gif
    Welded 12 bolt off-road with 31" or smaller tires and weak engine: /forums/images/graemlins/cool.gif
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You will break something. Welding to the carrier is the strongest (or should I say less weak) way. But it makes a field swap with spider gears impossible (unless you have an extra carrier). Getting the c-clips out when you blow up an axle (and you will) is a pain too. It really is not worth it in my .02
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Get a posi and don't mess with welding because you say that you will carry extra spider gears...that won't help because usually when it breaks it destroys the whole pumpkin. It's not worth the hassle and tire wear, you will be time and probably money ahead to just get a good posi. THe reason people weld spiders in the 14BFF's is because those carriers and spiders can usually take the punishment of being locked unlike a much weaker 10 or 12B.
  7. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Been there, done that. I would NOT recommend it. My 14B s/f broke within 30 days. The Detroit I have now is the better way to go.
