Welding a 12 Bolt????
Discussion in 'The Garage' started by Greenblazer-AZ, Mar 21, 2002.
  1. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Anybody have a welded 12 Bolt rear? Anybody have any input? I have 35" BFG Muds and do not plan to put bigger tires. It will be used on Rock Crawling trips occaisionally. I really only need it as a tempoary fix untill I swap in the 14 Bolt that I have. What I really need is to find a locker, but if I can't find one in time I might go the welded route.
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The 12 bolt in my buddys 4x Camaro is welded.It has a built 454 and he does not baby it at all and he hasnt broken it yet.
    If yer gonna swap it out later anyway I would do it.
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    A friend of mines friend as had his weded for 3 years..And no problems.. I am going to do it to my trail rig....Dan
  4. Greenblazer-AZ
    Jan 4, 2002
    770
    Chandler, AZ
    Thanks for the info guys! I think this is the way I'm gonna go.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    What kind of on road manners can you expect from a welded diff? Where exactly do you place the welds? I assume you just weld the spider gears to the carrier, right? And lastly, Anyone got pics of a welded diff?
    hehe, sorry for all the questions...But I am really curious about this too. /forums/images/icons/laugh.gif
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    This is for a 14 bolt.. But I assume they are the same..
    <a target="_blank" href=http://www.coloradok5.com/welded14bolt.shtml>http://www.coloradok5.com/welded14bolt.shtml</a>
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I saw that article....Although I was under the impression that there was another way to do this? What are the pro's/con's of each technique? Mostly, what kinda on raod manners/quirks as compared to a Detroit?
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I just welded mine and i have to say the road manners are pretty good except around sharp corners and parking. and even that i kinda like---it barks around corners. your tires WILL wear quicker but if you rotate them regularly it will help. i had a detriot in my 10 bolt and it took a little getting used to. just driving down the street it would like to engage on me just outta the blue. as of right now im gonna have to say i like the welded approach but id have to say its is not for everyone. you also have to realize the "welded spider gear" is only as strong as the weld, and even then the gears a re heat treated so the instant you put that weld on there it diminishes the strength I welded mine as a "temporary" locker also but we will see how long it lasts.
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The 'other' way to do it is to weld anything that moves to the carrier/forums/images/icons/smile.gif My 14 bolt is welded like the article for a couple of resons. #1 is i can always revert back to open cheaply, #2 I can always drop in a detroit in place of the welded spiders. and #3 is that just welding the voids between the teeth puts a whole lot less heat into the heat treated parts. So far my 14 bolt has been welded for 15 months with over 15,000 miles on it. It's holding up real well and hasn't given me a reason to regret doing it
    Rene.
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    And I assume th procedure outlined in the article is the same for a 12 bolt?
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Never done a 12 bolt...
    I'd have to have a good look inside and take it from there. I've seen similar welded diffs where the side gears are filled up rather than the spiders. If the side gears are larger I'd do that.
    rene
  12. Greenblazer-AZ
    Jan 4, 2002
    770
    Chandler, AZ
    Thanks again for all the input. I'll let you know how it turns out.
  13. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I had a 12 bolt in mine. All of my rear diffs get welded, you will really like it, I broke 2 12 bolts before going to a 14ff, they broke becuse of my heavy right foot not because they were welded.
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What did you break? I take it you didn't break the carrier...
