Welding a 14bff housing ?????
Discussion in 'The Garage' started by JK5, Jun 14, 2004.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have some missing spot welds on my 14bff..
    They are the spot welds that hold the left side axle tube...
    My question is...
    Can I weld the housing with a MIG with steel wire...
    or do I need to use a cast iron rod...and stick weld???
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Cast Iron rods and stick weld it. Mig just won't do the job.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    What about heating the tube up with a torch then mig welding?
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...Yah...that's what I figured..
    I just need to set-up an outlet for my Stick welder.. /forums/images/graemlins/doah.gif
  5. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    That should be ductile cast and was probably MIG welded from the factory. I'd preheat it and weld it up with MIG.
    Then again I have access to a 600 amp machine if I want. How big a machine do you have?
    Rene
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Hummm...
    They looked like MIG welds..
    I have access to a 250 amp Lincoln Mig..
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Any cast that needs welding is usually ductile cast. Things like sculley's (threaded drainhole thingy's). The fact that they press a mild steel tube into the ends of the housing and rosette weld them tells me it would have to be a ductile cast...otherwise it'd crack.
    Rene
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Thanks Rene...
    Maybe I'll take my truck to work friday...
    and do some MIG welding... /forums/images/graemlins/peace.gif
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    That went well!!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    I sandblasted the holes..
    pre-heated the housing..and the axle tube..
    Set the MIG welder at 24V...
    And put some plug welds back in...
    then threw a fiberglass branket over the housing..
    to let it cool slowly..
    It took about 1 hour to cool..
    No cracks!!!! /forums/images/graemlins/peace.gif
  10. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Good insurance, but the post weld treatment isn't really necessary. It's nowhere near as brittle as regular cast iron.
    Rene
  11. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    is this necissary for welding on the axle tubes, or just the housing? i basically know nothing about welding. i need to put some shock mounts on my tubes. i know a guy thats got a mig with gas that will do it for me.
    so, the proper procedure for mig welding the housing, is to just heat it up first?
  12. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    On the tubes a little pre-heat is OK. Basically get the moisture out of the material. On the housing same thing...get the moisture out. Either should be 150F or so before welding, no need to get carried away.
    Rene
  13. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I figured it would be a little overkill...
    But better safe than sorry..
    That was my first experiance with welding a housing..
  14. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    cool, thanks /forums/images/graemlins/bow.gif
