welding alum. with a mig
Discussion in 'The Garage' started by surpip, Jan 24, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    anyone do this?
    the smaller wire feed welders have the cap. to weld alum. just wondering if anyone has actually done this or not.
  2. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I don't personally, but we do it all the time here at the shop. Virtually all of out signs are aluminum and we weld them together with a mig welder. We have it set up with a separate gun and bottle. Straight Argon gas and the gun has a wire spool right on it.
    I know it takes new people some getting use to, but they seem to pick it up pretty quick.
    I wouldn't call ours a small welder. It is setup to run either the alum or steel. Just have to flip a switch and open the right bottle.
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    yes, i have welded alum. with a mig. i have layed down some bitchen to some really crappy welds. its hard to get a consistant weld each time you weld alum. its not like steel where you just flick it on and go at it. i have only done this with our Lincoln 175 plus mig at work. we have the kit to do alum for it. i did find that i had to wick the volt almost max and the wire feed has to be almost maxed too for it to weld with what i would say is good penatration. those welds looked alot better then the ones where the volts were less.
    i weld aluminum fixtures up from time to time here at work. i usually use steel but there are times where steel is too heave so we use alum. your alum needs to be real clean, stainless steel wire brushed. if its dirty it will spit and sputter something awful.
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    The smaller welders work better due to the length of the cable/torch assembly. The shorter the better. Long wire runs cause clogging.
    The best set-up is a big welder with a spool gun.
  5. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    Yeah, that's what I was talking about. That's the way ours is setup.
  6. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    yup, you need the power you get from a big machine, and its best to pull the wire rather then push it.
  7. goldwing2000
    goldwing2000 Guest
    It's a pain in the ass to MIG aluminum. Just TIG it. :waytogo:
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    oh of course let me run right out and buy a 1500 dollar tig machine so i can weld up the 10 projects i will need it for:rolleyes: :rolleyes:
    thanks for all the other helpful replies
    was just wondering cause all the small home depot/lowes machines say you can weld alum. with them, just wonderin if it was worth a crap or not to get the stuff you would need to do it
    its for the dash in my car so it needs to look good
    probally take it to a shop to have it done
    thanks
  9. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    if you want a really clean job thats what i would do. welding alum. with a mig spatters like hell, so you might not want the surounding area to get damaged from spatter. good luck with your project.
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    1500? thats a cheap tig that is capable of aluminum welding haha
  11. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    keep the wire to the gun as straight as possible. Also turn down the tension on the drive rollers. Both of these help the wire to slip instead of birds nest. I've had good luck welding Al with a Millermatic 251 without a spool gun.
  12. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    TIG welding is soo much fun! By far my fav. type of welding:weld: :waytogo:
    As far as welding aluminum with a mig, ive done it twice and it there was alot of splatter, and the gun broke twice (not when i used it)
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale....
    one word,,, can you say
    powermig350
    I use pulse on pulse... tig like welds from a mig....
    now the bad news
    its 5 grand
