welding around fuel lines???
Discussion in 'The Garage' started by bad_bo_ti, Aug 30, 2002.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    whats the best/safest way to weld around fuel lines, with out disconnecting them. thanks Chris
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Move them out of the way is the safest....but you can cover them with sheet metal or a welding "flame proof" blanket!!! Never weld around LEAKY lines!! /forums/images/icons/wink.gif
  3. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    The safest way is to remove them. But, at work I get paid off commision SO, I don't always do this. What I'll do is get a welding blanket(A real welding blanket, not just any blanket) and wrap the lines a couple of times. Be really carefull around rubber lines cauze sparkes can find their way through the folds.
  4. bad_bo_ti
    1,027
    OhiO
    well heres the thing, i am welding in a bracket/x-member in the rear for my new shock locations. it is the lines in the side of the frame, and i am welding inside the frame on the bottom, kinda like the UAV is set up. should i just go ahead and remove the lines, how hard is this or would it be a bigger problem since i would then have kind of a leak.. thanks chris
    also will aluminum foil be able to withstand welding spatter? if i do a couple layers?
