Welding bumpers straight to the frame?
Discussion in 'The Garage' started by SchnorrCS, Feb 18, 2006.
  1. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Ok, so when I bought my K5, the dude before me (Cali Hippy if that helps) put some really really lame Tubeish bumpers on it. Kinda think he was going for the whole "Baja" look. Hated them since the day I brought her home. Well, I finally got around to it, bought some 1/8 inch wall square tube and cut them with slash cuts on the end.
    Now for my question....I cut off the last maybe 3 inches off the rear of the frame, so the bumpers would be tucked in nice and close (Don't run a tail gate) and was gonna box em up make some brackets and bolt the bumpers on with some 1/2 grade 8 stuff. 2 on each side. Got to thinking, and it seems it would be stronger and help limit frame tweakage if I welded them straight on. Not really worried about the fact that I could never get them off, but can anyone think of any reason this is a bad idea? I really cant.
    I also added some of the tube that I cut off to protect the gas tank also.
    Thanks alot guys.
    cS
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    some people dont like the idea of things being permanent but thats up to you.
    make sure you can still access everything you need to before u weld them on,
    jon
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what he said. i personaly dont like the idea of welding ANYTHING to the frame because i have changed my mind so many times it will be a PITA to change later on in life. not if, but when for me.
    Grant
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Welded front and rear bumper. But, I was happy with how they came out and no plans on changing. 2" recevier front and back and truck can be lifted by them if need be.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    wouldn't that be alittle hard on the frame when it tries to "twist" and flex on things???
    sure it might help with stiffening up the frame, but they were designed to twist somewhat.
  6. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Don't think it will really hurt the flex much. There are already Plates in both the front and rear...I'd kinda equate it to a heavy duty bracing and boxing of that portion of the frame. Just a thought.
    UPDATE-Went ahead and welded the rear one on. All I've done in the front is chop down the factory turd, but I have a winch on the way, so I'm gonna have to come up with something cool. Personally, I kinda like minimal bumpers, real strong but real small so they don't catch on every rock that I get close to. Any ideas?
    Thanks,
    cS
  7. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Theres a good reason why the engineers who designed the chassis didnt weld the x members...think safety and metal fatigue when you plan these mods out.
    These frames are not that stiff so everything joined to them must be midly compliant. You cant address frame flex issues locally, you have to take an holistic approach.
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i agree, but since both the front and rear frame horns have a cross member 8 inches or so from the rear i belive them to be tortionaly strong enough to be able to catch a cracked weld here and there and not ahve a full bumper fall off IF YOU INSPECT once in a while...
    like i said before, im not for it, but dont see anything wrong with it. keep an eye on the welds though.
    Grant
  9. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Depending on the construction techniques I would have to agree with your reasoning, but he did mention the 'winch' word...if those welds fail I can guess it will most prolly be when the winch is loaded.
    I would highly recomend some stout bolting action around winch mounts. Its just so much safer.
  10. sandSStorm
    sandSStorm Registered Member
    Feb 16, 2006
    56
    Nebraska
    I would go against welding. You never know when you need to do some modifications. It would be a PITA ..
    my 2 cents
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Check your state laws. I know in Oregon, welded bumper mounts ONLY is illegal. Must have at least 2 bolts minimum here.
  12. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    All very valid points. I welded the rear bumper only. The winch mount will be of the bolt on variety and will have 6 grade 8 half inchers 3 on each side and the winch will be bolted to that. I run a chopped down factory front bumper so I'm not real worried about that. I'll post up when the winch gets here and I get that sorted out and all. Maybe then it will be time to be a paying member and post up some pics...
