Welding cast Alum Tranny housing
Discussion in 'The Garage' started by White Knight, Mar 15, 2002.
  1. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Okay I know all the stories about tigs with water cooled torches, but by damned I WILL weld this thing with either my Torch using LUMENWELD RODS, or with my A/C welder using aluminium rods!!! Anyone have any advice? before I jump on this puppy with both feet.
    White Knight (orginal and Texan)
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    OK, I have no experience here, but, what are you trying to do?
    Pete
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Make sure that the area is perfectly clean....Spotless inside and out...
  4. White Knight
    889
    Ft Worth,Texas
    I cracked, and broke off two pieces around 3/4 by 3inches off the top side, I plan on "V" grooving the cracked area, then laying down a weld, grinding it smooth then laying down one more over the top for strength, however being the first time I've done this with cast alum. I was seeking advice from the best place to get it. <font color=red>CK5</font color=red>/forums/images/icons/smile.gif
  5. BUSCO
    BUSCO Registered Member
    Mar 4, 2001
    38
    New York(11552)
    I don't know much about aluminum welding but, I found a page that has some info.
    muggyweld.com
    Hope this helps
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I hope you have a 'plan B'.
    Here is the problem. Aluminum tranfers and absorbs heat very quickly so it requires roughly double the heat to weld it properly. For regular aluminum this isn't normally much of a problem, but cast is usally cast because it's an oddball shape (like your bellhousing). Most cast pieces are very rigid, as well as being fairly brittle. Common problems are spiderweb cracking during or after the weld is completed. The enormous amount of heat causes rapid expansion of the material which leads to material stress and then the cracks.
    The best process for welding cast aluminum is MIG because it can get the heat and weld material down in the least amount of time which reduces the chance of cracking. The MIG will also likely end up with a fair bit of porosity due to the contaminents and imperfections in the cast.
    TIG would give you a better quality weld but requires a lot more heat.
    I'd look at the aftermarket bolt on bellhousing replacements. I think it was BorregoK5 that did this recently to a TH350.
    Rene
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    He did have some fitment problems but nothing he couldn't handle and it looks killer, plus it is a way beefier bellhousing...
  9. White Knight
    889
    Ft Worth,Texas
    Thanks, tryed today with no luck will try once more tomorrow, and if that don't work then I own a 100 pound anchor in the shape of a 700r I quess.
  10. White Knight
    889
    Ft Worth,Texas
    gave up with my equipment, called in a marker and the PROFESSIONALS are on it now!!! Thanks one and all for the input.
    White Knight
