Welding cast aluminium wheels
Discussion in 'The Garage' started by sebban, Dec 13, 2005.
  1. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    Since I have a hard time getting 15" wheels here in sweden for my 14bff swap, (most companies won't ship outside US) I was thinking about my options.
    Option 1), Fabricate steel wheels, get my 4 steelies, widen them, and get the centre from a 16,5" wheel. (easy but not so good looking)
    Option 2), Take my MT Classic II, weld the 6*5,5" holes shut, drill new holes 8*6,5". (my buddy works in a machine shop)
    My concern is the welding, what do you think, are the MT crap to weld or do you think it's possible?
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    I've done some emergency welding on wheels and had it work fine, but this is a touchy subject, and can be very dangerous if not done correctly..
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If I am not mistaken, the MT Classic II's are not 100% cast aluminum at the lugs. I believe they have a steel insert in the lug area for strength....
    Here is the description from their site:
    Classic style with a highly polished fi nish and polished hand holes. The M/T® stamp of quality and limited lifetime guarantee gives added value to this popular truck wheel.
    STEEL INSERTS IN LUG HOLES PROVIDE A STRONGER SEAT AREA
    HAND HOLES ARE POLISHED INSIDE FOR A MORE DISTINCTIVE & ATTRACTIVE LOOK
    HIGHLY POLISHED SURFACE
    HIGH LOAD RATING
    CHROME HUB COVER INCLUDED
    LIFETIME LIMITED GUARANTEE AGAINST STRUCTURAL DEFECTS
  4. sebban
    Jan 18, 2005
    63
    sweden
    Yes I know. :)
    But I was thinking about drilling them out and put a piece of aluminium in the hole and weld around it on both sides. Just not sure about the quality of cast aluminium... ;)
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Sorry. :doah:
    Have you tried Summit Racing. I'd think they would ship anywhere, but it could get pricey.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    M/T's used to be, and may still be made by Alcoa. In which case they should be forged rather than cast wheels.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    No, its a cast wheel.. The cheaper version of the Classic...
    "M/T® Classic II®
    Cast Aluminum Wheel"
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You won't be able to fit a 15" aluminum wheel on an 8 lug front end. The rim is too thick. There is barely enough room for an 1/8" thick steel one.
  9. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Find he wheels you want to run and get someone from here to ship them to you.
  10. sebban
    Jan 18, 2005
    63
    sweden
    I´m keeping the 10bolt up front.. So it´s only for the rear.
    IF I ever need to go Dana 60, I will get beadlocks ;)
    But I appriciate the info, thanks.
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Welding cast aluminum is pretty tricky, it acts like a huge heat sink so the machine needs to be set pretty hot and the rim should be pre-heated. Even so cracking is likely...
    I wouldn't trust those rims afterwards.
    Rene
  12. jeeptuff
    Aug 22, 2005
    158
    Arlington, WA
    I have to disagree, I have 8 lug 15's on mine now with no caliper grinding whatsoever..
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You missed the key word in the sentence... Aluminum
  14. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Weld them up, and re-drill them. No big deal! We have done it. Champion welds Beadlock rings on them all the time. It is just metal, in this case Aluminum, there are no vital organs, blood veins, brians or anything else you can hurt.
  15. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I've welded cast cylinder heads w/o issues. We usually heat them to couple hundred degrees first. Then weld. Then put back on the heater and slowly let them cool down.
    I also welded some cracks in a friend's Weld Wheels. Ah, the irony.....
    Anyway those wheel proceeded to crack down the HAZ. I think this was b/c I lacked the means to get them quite hot enough and the material was relatively thin for a wheel.
  16. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I have to assume if you're bothering welding on beadlock rings that those Champions are forged rather than cast...
    Rene
  17. MoonMan
    MoonMan Registered Member
    Mar 12, 2003
    56
    Tyrone, Pa
    If my memory serves me right, MT Classic II's have pressed steel inserts in the lug holes. This may cause a problem with welding the holes up.
  18. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    The Champion Beadlock company welds inner beadlock ring to cast wheels all the time. There is no problem in welding cast wheels.
  19. jeeptuff
    Aug 22, 2005
    158
    Arlington, WA
    My bad... I did miss it..
