Welding Cast Steel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cliffy, May 15, 2001.
  1. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    I think That's what pitman arms are made out of. Anyway I need to shorten mine. I've never explored welding cast-to-cast.
    I've heard people say that welding regular steel to cast steel is a problem but is welding cast-to-cast a problem??
    Coil sprung 71 blazer.
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    YES,it's a real pain and would need to be done by someone who is experioenced with welding cast,especially on such a crucial part.
    That is one part that you don't want falling apart while you're going down the road.
    I really don't think that the pitman arm is cast though.Even if it's not,I would recomend having a pro do it,for the same reasons,or find a replacement part for it.
    Chuck
    81 Blazer
    <font color=blue>does anyone have another F#@d that I can park on?</font color=blue>[​IMG]
    <font color=red><A target="_blank" HREF=http://www.chucks81k5.coloradok5.com>http://www.chucks81k5.coloradok5.com</A></font color=red>
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Get with tRusty K5, he's a welding guru and would probably give you some helpful hints.
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I really dont think you should be cutting these things and re-welding them. Even if you are a guru or not its a safety thing that gets me. Welds and metal can degrade over time, as anything can/will, and steering isnt something you want to loose. I have seen ghetto rigged legnthened, shortened, and "professionally" beefied arms all break. Right were they are welded. I am not down playing anyones skills as a pro or certified welder. I just dont want to see or read about anyone getting hurt. Thats my $0.02
    [​IMG] Dont steal my truck..I dont need anymore worthless junk over my fireplace.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That is not a piece that I would be welding on (or use if someone else did). That piece has a tremendous amount of stress on it and if it breaks, look out! Better not to take chances with pieces like that. I would recommend you buy one that fits your application. They aren't that expensive...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  6. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I wouldn't touch a cast or any other steering component. I would consider getting a new pitman custom machined though...
    If the pitman is not cast I still wouldn't weld on it, I trust my own work but it would always worry me. Life is too short to take any chances on steering components. If you absolutely must have a custom piece do not cut any corners and get it done right. Cutting an existing pitman and re-welding it does not fall into the category of getting it done right...
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  7. Cliffy
    Oct 8, 2000
    99
    They are pretty expensive the one I'm referring to cost me 76 dollars. and the one I had before this cost me 30
    I'm not going to weld this, I'm gonna move some other things to make this fit right.
  8. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Hi Guys, From what I remember, it is forged steel. Cast, then run through a press while it's still red hot. Wouldn't weld it if it was me. GOPHERKILLER
  9. Cliffy
    Oct 8, 2000
    99
    No need to fear for you lives while I drive down the road.
    I called parts mike and he's sending me a new one (NO SHIPPING THIS TIME!!!) I should see it by friday.
