welding exhaust pipes?
Discussion in 'The Garage' started by kumma, Jun 8, 2002.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Any problems with welding the muffler to the pipes.
    My exhaust has come off several times due to clamps loosing up so I plan on welding everything except the tailpipe and cat, it should be more stable with less clamps dont you think. any problems or reason not to do this?
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    go for it, just tack everything first then go nuts /forums/images/icons/laugh.gif
    NITRO
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Just don't burn a hole in the pipe. /forums/images/icons/smirk.gif
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Use a mig welder if you can. I cant get the small rods to arc very well on low amperage with my stick welder.
  5. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    pretty much got it all done, man what a difference without those cheap clamps. cant wait to try it out next week and see how it holds up. i used a mig welded and it work great even under the truck.
