Welding frame
Discussion in 'The Garage' started by 90K5, Dec 7, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My frame is cracked at the steering box...got the ORD weld in repair kit and am going to fix it at a friend's hose over the holidays. What kind of welder is needed to weld on a frame? They have an ARC welder...forgot the other info about it, but i think its only 110 volts...is that enough for fixing a frame? Will it penetate enough?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Arc will be fine in the hands of someone that can weld
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    we did mine with some 6010 or 6011 rod @ about 75 amps AC. make sure you grind the crack into a beveled edge before you start and that will get you all the penatration you want. plus 6011 is pretty good at that anyway.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Arc welding will work fine if the welder can deliver the current required. Check the instructions for the weld-on plate. It should give some details on which rod is best to use. /forums/images/graemlins/cool.gif
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'm gonna use a mig.
