welding galvinized corrall pipe
Discussion in 'The Garage' started by surpip, Jun 5, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hey im going up to my boss's hous to weld some coral pipe with a millermatic 125 Anny ideas about wire speed and heat?
    thanks,
    dale /forums/images/graemlins/1zhelp.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    can't help you, but VENTILATE. You need to ventilate the area when welding galvanized. Stuff can do some damage to your lungs. Many people simply will not weld it. To ventilate well means you may be blowing your gas away a little bit, thats easily fixed by cranking the gas pressure up a little bit.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    coool thanks alot!!!! /forums/images/graemlins/waytogo.gif
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    welding galvinized is a bitch, it pop sputers it cloges you tips up and limits penitration, crank up your heat but watch it the pipes thin and you'll burn though if your not carefull. If you can try to grind off the coating off from the ends you welding just a bit mabey 1/4 inch.
    and give your self a small gap inbetween the pipe a 16th and it will give you better penetration, and your boss wont be pissed. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
    oh and silver spray paint is a nice match to galvinized pipe! cover your welds and it will loook great /forums/images/graemlins/waytogo.gif
