welding guys (fuel oil tank it cut it up??)
Discussion in 'The Lounge' started by ramjet gmc, Jan 27, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Can some of you welding guys tell me the safe way to cut up a fuel oil tank it is a 250 gal /forums/images/graemlins/1zhelp.gif
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Have someone you don't like do the job /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif
    Does it have fresh oil in it? or has it been empty for sometime?
    Eric
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    can u wash it with water first?? if not, is there n e way u can put some CO2 in there?? just throwin out ideas, but u could get a CO2 fire extinuisher and fill the tank up with it and keep doing that till the job is done. just throwin out ideas /forums/images/graemlins/confused.gif mayb burn ne thing in it first
    NITRO
  4. ramjet gmc
    Dec 19, 2001
    3,370
    The tank has been empty for over 5 years and is vented to the outside
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    how will u b cutting it?? do u have a plasma cutter?? or torch? a torch is gonna take a while. whatever u do, good luck. o ya, if it is thin enuff, take a stick welder, crank it all the way up and go nuts. that will cut it
    NITRO
  6. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Sorry it took me so long to get back with you on this.
    I asled the welders at work what they would do. The one I asled said there will be still resido (sp) In the tank even after five years seeing as it was oil in the tank. He thought the worst would be a fire and should not blow up on you.
    Hope this helps some
    Eric
  7. ramjet gmc
    Dec 19, 2001
    3,370
    i have a gas torch mabey i should ues a sawzall /forums/images/graemlins/rolleyes.gif
  8. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Run a hose from your exhaust of your vehicle down into the tank and it will kill the oxygen in the tank. This will keep it from exploding or burning, but you will need fresh air for yourself. /forums/images/graemlins/thumb.gif
