Welding on a Bolt
Discussion in 'The Garage' started by rockink5, Jul 5, 2006.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    To make a long story short, What is the opinion on welding a bolt head in place so it can not be removed with out some work. I wasn't going to weld continuous around it, just spot it on the wrench surfaces. Will the heat have any real effect on the bolt strength? Warn only supplied 5/16 bolts to begin with so I'm a little concerned about weakening cause' there not a whole lot of room for a larger bolt. Some one tried to steal my winch:angry1: , now I'll make it really difficult to remove, although it wasn't easy before, thats why it's still there.
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I did that with my winch. Even if you only did it to 2 of them its going to make it way harder for them to steal it.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I tack welded a 1.5x1.5 piece of angle over the rear bolts.
  4. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    I really don't see a quick spot weld affecting the bolt strength too much. I would just make sure it is a quick weld and letting it cool completely between welds if doing more than one.
  5. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Just a tack weld should be fine on outer edge of bolt head. Just did mine yesterday for same reason.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    nothing wrong with it in my opinion. don't sit there and just melt it but yeah I've done it before and will again. welding a nut in place is more difficult but still easy(have to run a tap through it afterwards is all). Just make sure the bolt is tight before you weld it. don't want it to be able to be puting clamping force on the welds, just using them to keep it from spinning.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    That's what I am planning to do with mine. Only thing is, I also plan to spot weld some of the bumper bolts on too.
