welding onto frame??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by barbastard, Jul 22, 2002.
  1. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    I'm getting ready to fab up my new front bumper and winch support box. However my design involves adding on some length to the front frame horns to clear the winch. To do this I plan on welding some steel channel to the ends of the frame horns and then welding in some 4x6x1/4 tube steel between the frame rails to support the winch. My question is this...I've heard that welding onto the frame is bad and not to do it. If I remember correctly what was stated was that it would weaken the frame and/or the welds wouldn't hold due to frame flex. Is this true or just an unfounded rumor. Please advise. All welds would be done using a lincoln arc welder and if need be I could preheat the frame rails to accept the welds and reduce the chances of differential temperature warping.Thanks for the help...
    Nate
    AKA "Barbastard"
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    *unfound rumor*
    Assuming you weld correctly, it will be just fine. Yes the frame flexes and its designed to do that, but if you do it correctly it will not weaken the frame at all.
    There were other rumors I heard where the frame was heat treated and required special welding techniques too. Complete hogwash /forums/images/icons/smile.gif
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I've heard the same BS about the frame material. It's stamped mild steel...anyone that disagrees is welcome to find any link proving that statement wrong. It's actually kinda funny...GM spending the bucks to heat treat the frames? Bawahahahaha!!!! It only took em 35 years or so to fix the poorly designed valve cover set-up on the sbc...
    Rene
  4. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    The above posts are right. I would not pre-heat it, just weld it.
  5. Waxer
    1,857
    Long Beach, CA.
    We didnt say anything about pre-heating. We said that the myth of the frame being "heat treated" for additional strength is false.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have welded to the frame and have seen it done so much that I can assure you that, done properly, it will be stronger than the surrounding frame. However, I would reccomend building your whole bumper assembly so that it can be bolted onto the frame.
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Both my bumpers are welded on. My cage plates are welded on. The weld on frame fix kits ord sells are, well, um, welded on. No problems. Don't believe everything you hear, some folks will spout shinola all day long if someone will listen.
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Proper welding (clean metal, proper ground, right welder settings, etc.) will do the job very well. But consider how hard getting your sheet metal off later will be if you create something that gets in the way. Or do you think it would be easier to modify your mounts later (if you change winches for example) by unbolting the mount and working on a table or would you rather try to modify it on the truck? Bolt on items can me made strong enough also and let you work on it later with out as many hassles.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the flame wrench removes almost anything
  10. JMZ
    Dec 4, 2001
    73
    Gonzales , Texas
    WAXER, barbastard said he could preheat it if he had to, thats what I was reffering too.
  11. kennyw
    Jun 9, 2002
    13,223
    94
    Yes but does not as easy and increases the chance for damaging components. Not to mention it is harder to put the bumper back on right...
    Either meathod will work and be just as strong when you look at the mounting point just think about what you are willing to deal with later on.
  12. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The only thing I may be concerned with is welding the tube between the frame rails. Am I understanding correctly that you would be tieing the front frame rails together. I don't know if that will cause any undue stress under flex, but it may. Something to think about.
    John
  13. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Do it, I have a Warn original winch bumper and a 8274 winch, which I welded to the frame with 5-p (60-10) and have had NO problems
    I did not however weld a brace between the two frame rails,
    On flex, it (the bumper) does move alot
    I also mounted the bottom of the bumper mounts at the top 2/3rd's of the frame, helps with clearance issues and departure angle
    Good Luck!
