welding question.. is a Mig welder 110 volt enough to ...
Discussion in 'The Garage' started by rocko, Aug 21, 2003.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Weld my spring perches on? I've got to know quickly.. I borrowed a friends welder.. or should I just have it stick welded..
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I have a 110 Lincoln Mig welder. I am by no means a welding expert but I do know I can burn through damn near anything on my rig with it. I assume, if you can burn a hole through the material, you have more than enough power to lay a good weld.
    I have not used it on the axle tubs but I am sure I could with good results.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    with the 110 v i say no i am not that good i would be tough with my 220V but can be dun i and just a low level welder
    any pro welders out ther????
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Turn it all the way up and go slow and you should be ok. 220 would do a better job, but it is possible with 110.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    How many amps does the 110 put out? I have a 135 amp 110 and I think it can be done with it, but I would probably do about three passes and burn it in slow. I wouldn't trust a single pass weld with a 110.
  6. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    no no no little boy.
    If my plug works in you outlet you can have Russel come pick up the stick or the Miller mig. welder to do the job. /forums/images/graemlins/thumb.gif
  7. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    just make sure you dont do it all at once. if it gets to hot you could warp the tube. not to suggest you didnt know that, just making sure.
