welding questions?
Discussion in 'The Garage' started by smprider112, Aug 12, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Ok, so I have maybe welded twice in my life...but what the hell U only learn by doing...so I need to weld the seems of my bed where it has been narrowed, I have access to a 110 wirefeed welder, from what I have been told this will work for body sheetmetal pretty well....but now for the questions, what should I set the welder to? like the amps and wirespeed and stuff?? also will it matter that there is bedliner on my bed or will the welder just burn through that no prob...or should I grind it down first?? anyways any tips or tricks would be cool too!! /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    grind it, the cleaner the better.
    /forums/images/graemlins/weld.gif
  3. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    Are you going to be trying to butt the two pieces together? if at all possible make a piece that will go behind it and use a series of spot weld {stiches}. You also need gas and not just flux core. Just learned all this the hard way. Any other questions I will try to help. Oh yea, set it on the lowest setting and play with line speed.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    it should say the wirespeed and voltage for the machine on the side cover.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    also keep in mind that you have to have a place to hook your ground clamp to bare metal so it prolly wont work with the bedliner on there.
    -Chris
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    bare metal, for ground and for the gun too
    shiny is best, make it such for best weld performance
    settings you just have to play around with and fine tune with,
