Welding relocated shock mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ron, Jul 19, 2001.
  1. Ron
    Ron Registered Member
    Jun 9, 2001
    55
    Washington
    I would like to relocate my bottom shock mounts on the axle housing. Is it Ok to weld on the housing of course I will drain the lubricant first is there anything else I should know about? Thanks Ron
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Just clean off the old paint and grease real good and grind yourself a clean ground and thats all you have to worry about. You dont have to drain the fluid at all. Hope this helps.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  3. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    As waxer said just make sure you clean everything off the axle to be welded. Just keep in mind that oil and grease will burn very well too. As far as the fluid is concerned I would leave it in there and change it after you do your welding.......the 1500 degree heat from the welding is going to break down the fluid real quick. The fluid being inside the axle will actually have a cooling effect on the rest of the tube preventing warpage and such. Just my $.02.
    J:(P it's what's for dinner!
  4. Ron
    Jun 9, 2001
    55
    Washington
    Thanks alot for the info guys its a bighelp. Ron
  5. CST-30
    CST-30 Registered Member
    Jul 16, 2000
    58
    St. Joseph Mo.
    Keep your ground close to the area you are welding and you shouldnt have any problems.
    72 K-5 cst blazer 2 1/2 lift 33" bfg's
    69 custom 30 longstepside 4x4 6" lift 36" directionals
    87 K-5 stock
