Welding sheet metal with an ARC welder?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGJ, Oct 3, 2001.
  1. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Can you weld sheet metal with an arc welder? I'm not talking about 1/4" plate or anything like that, but more like fenders and rockers. I don't have any experience with the really thin stuff, and before I go and burn some holes in my blazer I thought I'd ask. If it's possible, what rod and setting do I use? I have a Lincoln 220 AC arc welder at home but no mig yet. If it won't work then I guess I'll have to bum a mig from someome. Or maybe pick up a christmas present to myself a few months early [​IMG] .
    Thanks,
    BIGJ
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Welding body panel's with Stick is extremely tricky and frustrating. Buy or borrow a MIG.
    Rene
  3. BIGJ
    896
    Central Arkansas
    Thanks. That's what I figured, just wanted to be sure.
    BIGJ
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    It can be done but it's messy and unless you are good with a rod you'll have to repair alot more than you planned on repairing.....
    Mig can also be messy and make more work than you wanted if you not carefull.
    Eather way....go get a scrap piece of metal from a bone yard and practic if your not use to welding on body parts.....
    C'moe
    Kill Roy was here!
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    What about welding sheet aluminum with oxy/acetylene. Generally, I know this doesn't work well, its a heliarc job, but I've heard success stories in the past. I'm looking at spot welding some aluminum diamond plate. Do you know of a technique that might work?
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've welded aluminum with the torch - it's a PITA -to do a good job you have to use heat sink compound, and flux coated rod.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Excellent, I knew I'd have to run the heat low on the torch but didn't think about the heat sink compound. Thank you!
    What, Me Worry?
  8. You can weld sheet metal with welding rod (6011 or 6013 3/32"), but it is not for amatuers. The sheet metal will distort also. If the sheet metal has any rust whatsoever on, no matter what welding process you use, the second you strike an arc, you will blow a hole through the metal. If you know someone who is a good welder (i.e. someone that earns their living by it), they may be able to weld your sheet metal with stick. If not, borrow a MIG.
    God has a hard on for Marines, because we keep Heaven chock full of fresh souls!
  9. Grim-Reaper
    7,385
    Atlanta
    Get some 6d nails and a hammer and use them to joint the metal. You will be more sucesfull [​IMG] Don't bother to buy those real expensive thin rods. still doesn't work and horrible spatter.
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  10. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Or better yet, get some JB weld. [​IMG]
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I weld for a living...the best thing for the job is a TIG welder, second would be the MIG, third would be the JB weld, fourth would be Grimmy's nails, and if absolutely none of those were available to you I still would not recomend welding that paper thin steel with a stick welder.[​IMG]
    They do make small diameter rods specifically for welding body panels...but they don't work worth a damn.
    Rene
  12. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I also weld for a living and my choice's would be tig(heli-arc)then resistance weld , then mig,then jb weld
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I am no expert welder but I'd stay away from arc too. I tried using it for exhaust pipe once just to temporarily tack it there to quiet it down until I could get new pipes. It was a waste of time.
    Tim
  14. 78Jimmyish
    78Jimmyish 1/2 ton status
    Jul 28, 2001
    137
    Rhode Island
    Yes..and no. It can be done - but definately not for the faint of heart... If you know a friend with a TIG or MIG, it'd be a WAY better idea to pay him for his time and materials. Although if you've got a couple of junk body panels, practice a litlte bit, you may find you have a knack for it. More than likely not though, that kind of thing seem to be all about practice - my old boss used to do it all the time and it'd look like it was welded with a TIG.
  15. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can get a stitch welding attachment for your AC machine for less than $100 from Eastwood - they work pretty well, but take quite a bit of practice to do a good job with.
